Aktivacija android auto in carplay na Rlink2
Vse o ozvočenju avtomobilov
lukaeva
Prispevkov: 10
Pridružen: 24 Avg 2017, 17:42
Odgovor Napisal/-a lukaeva »
Ali je že Kdo probal. https://youtu.be/olpNGkrxdcQ
IcEm4n
Prispevkov: 1788
Pridružen: 12 Jul 2007, 18:45
Kraj: LJ kotel
Re: Aktivacija android auto in carplay na Rlink2
Odgovor Napisal/-a IcEm4n »
Če prav razumem, ta DeveloperSide meni "odkleneš" z USB ključem (zasledil v enem drugem videu). Še postopek (c/p iz enega videa):
How do I get into developer mode? (translated from german forum)
- Create a blank USB flash drive with fat32 filesystem
- Create a folder called DEBUG, and in this folder create an empty file called DbgEnable.lge
- put usb in the car
- go to the main menu (with the 6 large icons) Menu> Multimedia> Settings> Photos
- remove previously inserted SD card or USB card in the car
- insert the "new" USB stick and start the engine
- wait at least 30/45 seconds (until "USB drive is ready")
- now you have to press in the black square that you see on the screen (below the two menu items) in the following order: 1 time in the upper left corner (leave at least 1 sec between presses) and tap at least 12 times in the lower right corner (stay within the rectangle)
- if all goes well, the complete R-Link screen will be blank, then you will get a debug mode!
Če bo kdo preizkušal, naj še zapiše, na kateri verziji - ali 2.x ali 3.x.
Ni brzine brez turbine! :D
kingo
Prispevkov: 63
Pridružen: 10 Jul 2010, 19:46
Odgovor Napisal/-a kingo »
IcEm4n napisal/-a:Če prav razumem, ta DeveloperSide meni "odkleneš" z USB ključem (zasledil v enem drugem videu). Še postopek (c/p iz enega videa):
S pomočjo kolega iz tega foruma, mi je uspelo. Sedaj dela video med vožnjo pa povečevanje glasnosti med vožnjo, kar pred tem na mojem Kadjarju ni bilo možno. Imam sicer FW 2. Je pa stvar v tem, da je njemu uspelo priti v meni z 2x klikom na levi strani in potem 12x na desni strani ekrana. Pa DbgEnable.lge mora biti dolg 1kb.
_____________
Renault Kadjar
1.6 TCE, 2017
Bose Edition
lukaeva
Prispevkov: 10
Ali se da še kej aktivirat razen gledanje videa med vožnjo?Jaz bi tudi probal pa neupam da nabom kej zaj....Če mi lahko pomagaš dam za pivo,,Lp
kingo
Prispevkov: 63
Nastavil sem si še, da mi na zaslonu izpiše npr. (stopnja ventilacije, ves čas imam tam prikaz temperature.... Samo, kot sem napisal, meni je kolega pomagal z USB ključkom in pravim fileom (1kb). Zajebati pa nimaš kaj, ker tam imaš možnost save ali pa greš preprosto ven iz naprednega menija in to je to.
_____________
Renault Kadjar
1.6 TCE, 2017
Bose Edition
lukaeva
Prispevkov: 10
Evo danes sem probal pa mi ni uspelo,delal po navodilh.Ne vem kaj sem delas narobe.Imam scenica let.2017 edition one.
lukaeva
Prispevkov: 10
Evo danes mi je uspelo z pomočjo uporabnika kingo in vključil android auto in CarPlay.Iphone dela,android pa ne.Nevem nekje sem prebral da v Sloveniji še ne dela ker google play ne podpira slovenščino.Ali kdo kej ve o tem.Lp
IcEm4n
Prispevkov: 1788
Kraj: LJ kotel
Android Auto uradno res še ni na voljo pri nas, se ga pa vseeno da dobiti: https://www.apkmirror.com/apk/google-inc/android-auto/
Drugače pa meni tudi ni uspelo priti v ta meni, predvidevam, da zaradi neustreznega file-a.
Lahko še meni kdo pomaga? :mrgreen: :mrgreen:
lukaeva
Prispevkov: 10
Danes usposobil android auto.
clashofmagic
Prispevkov: 1
Pridružen: 25 Jun 2019, 14:02
Odgovor Napisal/-a clashofmagic »
Danes usposobil android auto. ???
zakumi
Prispevkov: 1400
Pridružen: 29 Sep 2012, 17:23
Odgovor Napisal/-a zakumi »
Aktiviral Android auto,kako aktivirati Google Play?
Poslano z mojega Pixel 3 XL z uporabo Tapatalk
IcEm4n
Prispevkov: 1788
Kraj: LJ kotel
Misliš Apple Carplay? Če se prav spomnim, je glede CP malo več zafrkancije.
zakumi
Prispevkov: 1400
Mal zbrkal mislil carplay za android.
IcEm4n
Prispevkov: 1788
Kraj: LJ kotel
Bi rekel, da si marsikaj zbrklal. :D
Android telefon => Android Auto
Iphone => Apple CarPlay
Mirrorlinka pa Rlink2, kolikor je meni znano, nima.
zakumi
Prispevkov: 1400
Deluje,jupi.Slika Google play, YouTube...Slika
