Renault Master-minibus
ban84
Prispevkov: 22
Pridružen: 04 Nov 2012, 01:29
Odgovor Napisal/-a ban84 »
Pozdravljeni.
Tast ma zgoraj omenjen kombi. Uredu stvarca. Servisira ga sam, sedaj pa ga zanima kako bi po servisu izbrisal kilometre in lučko SERV. Za mojega Espace-ta sem tu dobil informacije. A obstaja kakšen podoben sistem in če ga kdo pozna naj mi ga opiše. Hvala za vse informacije.
Cefizelj
Prispevkov: 1156
Pridružen: 08 Mar 2010, 11:47
Re: Renault Master-minibus
Odgovor Napisal/-a Cefizelj »
Stric google pravi tole :D
http://www.outandaboutlive.co.uk/forums ... sh-/30048/
after a little more "googling",it appears as if this is/may be a service interval indicator of sorts(..although odd that it isn't mentioned in the handbook).
As for the method for "turning it off"/zeroing it...well!...I would've never stumbled across that..?!
As it involved:
1) turning ign' off,
2) depressing the throttle,
3) turning key on(two clicks)
4) and whilst still depressing the throttle press the brake pedal three times.....
5)..turn keys "off".... Finish...Easy...
Well,the "spanner" has gone..but lets just hoped I haven't b*ggered something else up!
edit:Thanks for that RobinH'..Sorry I missed your post.
At least the chap in your link used a similar method.
(..although I see someone makes a reference to the "trip computer" section of the handbook but as we haven't got one fitted I hadn't checked that section.... )
Thanks again....
EDIT:
Še ena metoda očitno:
http://www.howtomendit.com/answers.php?id=147022
ban84
Prispevkov: 22
Hvala za pomoč, bomo poizkusli in napisali o rezultatih.
