Megane III shema varovalk
Free_style
Prispevkov: 168
Pridružen: 01 Nov 2008, 21:57
Kraj: Celje, Laško
Odgovor Napisal/-a Free_style »
Ima kdo shemo varovalk, ne tisto ki je v knjigi, ampak točno sliko kjer se vidi katera varovalka je za kaj?
Rabil bi čimprejjj=)
Hvala
Free_style
Prispevkov: 168
Kraj: Celje, Laško
Neki takšnega=)
denisk
Prispevkov: 522
Pridružen: 06 Mar 2011, 21:44
Kraj: MS-Ljubljana
Odgovor Napisal/-a denisk »
a si se kaj igral z montažo LED žarnic v vrata in podobno?pa ti jih je skurlo? :D
Clio IV RS EDC 2015
Free_style
Prispevkov: 168
Kraj: Celje, Laško
Neki takiga, se je teb tud to zgodilo?=)
denisk
Prispevkov: 522
Kraj: MS-Ljubljana
Free_style napisal/-a:Neki takiga, se je teb tud to zgodilo?=)
ne, sem pa bral po britanskih forumih. čaki, bom tam prebrskal, če je kdo napisal kje najdeš varovalko.
Clio IV RS EDC 2015
denisk
Prispevkov: 522
Kraj: MS-Ljubljana
evo, tkole eden pravi:
Fuse 18 if I remember correctly its like hidden abit.. I ain't at my car to be 100% .. but it is a 15 amp fuse. Total ballache to get out. You need little fingers. Top right under the bonnet.. there is some red sliding clips to get the first cover off. Then under there. There is like a box with wires going to it. There is 4 black rubber bits that should just slide up with this box. It's all tight not much stretch in the wires. Under There is the fuses. There is only one maybe 2 15 amp fuses under There so you can't really go wrong. Sure its 18... There is a thread on here somewhere about it.. the spare fuse and the thing to get the fuses out are in the glovebox on the left... This is what I got told to change under the bonnet. Like I say the fuse was fine .. still haven't sorted it. Might put all old back in and take it to reno .. let me know bud..
potem v enem drugem postu piše, da obstaja še možnost, da je odneslo varovalko 20 ali 21. ampak najverjetneje 18, s to je večina imela probleme.
poglej pod havbo varovalke, javi če je to to :)
v bodoče, ne z izvijačem zamenjavat žarnice ;)
Clio IV RS EDC 2015
Free_style
Prispevkov: 168
Kraj: Celje, Laško
Kako pa vem katera je 18?=) Drugače pa je izvijač me je zajebu oz. sem se sam.
OFF: ti imaš na tvojem ledice notri, če ja katere?
denisk
Prispevkov: 522
Kraj: MS-Ljubljana
glej tiste, na katerih piše 15. menda sta 2 ki sta 15 amperski. ena izmed teh dveh bi morala biti.
jaz se še s tem nisem ukvarjal, čeprav pa sem že premišljeval. Kakšne barve LEDice imaš? bele?
Clio IV RS EDC 2015
Free_style
Prispevkov: 168
Kraj: Celje, Laško
bele ja ampak niso ok, bom te verjetno vzel ampak za cel avto torej tud za notr vrate, strop,parkirne luči, oranžne za smernike,...ipd
http://www.ebay.co.uk/itm/2-X-501-W5W-T ... 835wt_1402
denisk
Prispevkov: 522
Kraj: MS-Ljubljana
ko ti uspe rešit zadevo javi, da bom pol tut jst montiral ;)
Clio IV RS EDC 2015
Free_style
Prispevkov: 168
Kraj: Celje, Laško
Hvala @denisk u ker mi je pomagal rešiti problem z varovalkami, torej pod pokrovom desno zgoraj je še ena škatla z varovalkami če bo kdo iskal. Je treba pa odpreti 2 pokrova. Glede ledic pa sem probal danes še malo boljše oz. dražje in spet ni šlo, ledica komaj gori oz. sploh ne gori. Ima kdo kakšno idejo katere bi delale?
Hvala
Free_style
Prispevkov: 168
Kraj: Celje, Laško
Baje sem našel rešitev,...javim ko zmontiram oz. dobim
http://www.superstrela.com/content/led- ... uporom-12v
denisk
Prispevkov: 522
Kraj: MS-Ljubljana
Free_style, ni problema.
te delajo 100%:
http://shop.meganesport.net//product_in ... ucts_id=56
lp, denis
Clio IV RS EDC 2015
Free_style
Prispevkov: 168
Kraj: Celje, Laško
Free_style napisal/-a:Baje sem našel rešitev,...javim ko zmontiram oz. dobim
Tudi te delajo super;)
Nejko
Prispevkov: 684
Pridružen: 04 Apr 2005, 10:01
Odgovor Napisal/-a Nejko »
Sem šele sedaj videl tole temo....
Za v vrata se zagotovo potrebujejo ledice s canbusom, mentedm ko lahko gredo v stropno in drugo razsvetljavo tudi navadne w5w ledice.
Na mojem Grand SCenicu sem imel tudi probleme v vratih, sem tud nekje pisal o tem na forumu, sicer ne tako močne, da bi mi skurilo varovalke. V voznikovih vratih se mi je vedno ugašala po nekaj skndah, medtem ko so vse ostale "po malem" ves čas gorele, kar je bilo sploh ponoči rahlo moteče. Sedaj sem montiral v vrata canbus ledice in tudi delovanje vseh ostalih se je popravilo.
Bi ti pa svetovl razmisleh pred nakupom ledic za vse ostalo, kot si rekel, oražnih za smernike in tako naprej.... Sam še imam dve oranžni, ki sem jih predvidel za smernike spredaj, vendar se mi zdi svetloba, sploh podnevi, premalo razločna...lahko ti ih posodim, pa poskusiš.
BMW 323i (1983)
