diagnostika na števcu clio II
Uporabni vodiči
bfranc
Prispevkov: 358
Pridružen: 11 Sep 2008, 09:42
Kraj: Dobrepolje/Kompolje
Odgovor Napisal/-a bfranc »
Slučajno našel ,na tem forumu pa tudi še nisem zasledil.
Sem pa naredil kar copy/paste:
Theres a simple diagnostics built into the Mk2 Clio's
To access this, with the igition off press and keep hold of the button at the end of the stalk and turn the ignition on. ALl the dashboard warning lights will come on and the speedo and rev counter will go through a predefined sequene.
When your doing this though (you can let go of the button at the end of the stalk) ever time you press the stalk button the digital readout will show information (listed belew) each time you press the button some more information will show.
All the lights lit (shows if you have a failed LED).
The amount of fuel left in the tank in liters.
Fuel flow (the engine has to be running. This is in liters per hour
Stored faults:
t = mean an injection fault has been detected for a minimum of 4 seconds
J = means a fault has been noted on the fuel gauge. It must have disconnected for longer than 100 seconds. The resistance from the fuel tank sensor needs to be between 5 and 350 Ohms.
d means an injection signal fault has been detected
h means an oil level sensor fault has been detected. Resistance from the sensor should be between 6 and 20 Ohms. Any reading over 20 Ohms is an open circuit anything under 3 is a short circuit.
If no faults are logged then dashes will show fixed dashes.
Press the reset button to clear the logged faults. Other faults arn't shown on the display
