daljinsko zaklepane, laguna 97
Demshy
Prispevkov: 11
Pridružen: 17 Mar 2008, 14:43
Odgovor Napisal/-a Demshy »
vem da je to ze miljonta tema o tej okvari, ampak mi zares nobena ni pomagala.
opazil sem eno cudo, ki ga se noben ni omenil:
- drzim gumb (v avtu) za zaklepanje par sekund
- avto se odklene in zaklene, lucka na gumbu zacne goret (in ne vec utripat)
- ce zdaj poskusim s kljucem potem klikne (mislim da se poskusi odklenit, ceprav je ze odklenjen) in zacne spet utripat
v VSEH drugih moznih primerih se s kljucem ne premakne nic, notranji gumb pa dela normalno. pa baterija je ok.
predvidevam da je torej napaka v relayih zraven varovalk, ali pac?
Shusuglao
Prispevkov: 5154
Pridružen: 18 Feb 2003, 19:27
ce ti kaj od tega pomaga
(nasel enkrat na netu, nimam pojma ce dela)
REMOTE CONTROL PROGRAMMING
RENAULT
CLIO II, KANGOO & MASTER INFRA RED RESYNCHRONISING
1. Turn Ignition OFF.
2. Press the central door locking button for more than 5 seconds. Note : the door should
lock then unlock.
3. When this happens, 10 seconds is allowed and the immobiliser warning light illumi-
nates.
4. Point the 1st key at the receiver and press the button twice, the doors should lock and
unlock. Repeat for other remotes as required.
5. Check the remote control unlocks and locks the doors.
LAGUNA II & SAFRANE II INFRA RED RESYNCHRONISING
lock then unlock.
3. When this happens, 15 seconds is allowed and the immobiliser warning light illumi-
nates.
4. Point the 1st key at the receiver and press the button once, the doors should lock and
unlock.
5. Point the 2nd key at the receiver and press the button once, the doors should lock and
unlock.
6. Check the remote control unlocks and locks the doors.
CLIO II, KANGOO & MASTER RF RESYNCHRONISING
lock then unlock.
nates.
4. Press the remote control once, the doors should lock and unlock.
5. Repeat for second remote if required.
LAGUNA II & SAFRANE II RF RESYNCHRONISING
lock then unlock.
nates.
5. Press the second remote control once, the doors should lock and unlock.
CLIO RE-SYNCHRONISING
1. Lock Car manually
2. Unlock Car manually
3. Insert key into ignition within 30 seconds.
4. Turn Ignition and start vehicle.
MEGANE RF RESYNCHRONISING
Hold the remote control button down for longer than 10 seconds (until the red tell-tale light on the key
extinguishes) then press it again 3 times.
Check that the doors lock and unlock correctly.
MEGANE WITH EARLY REMOTE
(LED SWITCHES OFF WHEN HOLDING BUTTON
DEPRESSED)
1.
Igniton ON
2.
Press and hold the central locking button for 5 seconds
3.
LED on the dash board will go off, come back on and begin to flash. The flashes correspond to
the first digit of the 4 PIN security code- release the button when the first digit has been
"flashed" and then press the button again.
4.
Wait for the second digit to be "flashed" then release and re-press the button- continue until all
digits have been entered.
5.
If you have entered the code correctly the LED will then go out and the car can be started- to
code the remote, switch off the ignition and press the central locking button again.
6.
Press remote button 2 times within the immediate vicinity of the pick up (in the roof) On some
vehicles you may need to switch the ignition back on to achieve this however.
Demshy
Prispevkov: 11
lock then unlock.
nates.
unlock.
unlock.
sem poskusil vse variante in mislim da bi morala bit tale, s tem da se ustavi pri 4. koraku, vrata bi se mogla zaklenit in odklenit, on jih pa samo poskusi odklenit (ze odklenjena)..
