SE IZPLACA????
Vse o videzu avtomobila
MDeeJay
Prispevkov: 506
Pridružen: 05 Mar 2003, 02:37
Kraj: MARIBOR CITY
SE IZPLACA????
Odgovor Napisal/-a MDeeJay »
MALO POGLEJTE STRAN TER CENE IN MODELE TER POKOMENTIRAJTE, DA VEM ALI NAROCIM ALI DAM RAJE KOMU TUKAJ DELAT (beri CENEJE)!!!
http://www.litewave.co.uk/index.htm
HVALA!
birkoff
Prispevkov: 1168
Pridružen: 26 Apr 2004, 00:05
Odgovor Napisal/-a birkoff »
Kaj bi pa ti kupo?
Kolko pa stane posiljanja artikla v Slovenijo?
HaBBicH
Prispevkov: 871
Pridružen: 18 Feb 2003, 16:21
Kraj: Kranjsterdam
Odgovor Napisal/-a HaBBicH »
Sam si nared ti rt lena :D
Big wheels keep on turnin' :D
PRODAJAM VELIK STVARI
MDeeJay
Prispevkov: 506
Kraj: MARIBOR CITY
birkoff napisal/-a:Kaj bi pa ti kupo?
VSE TI PISE, SAM MORS STRAN CELO POGLEDAT!!!
MDeeJay
Prispevkov: 506
Kraj: MARIBOR CITY
Blue Kit - £159 (includes 4 tubes & controller) (out of stock)
We have the new ULS400 - Flat Bar Scanning Kits in Blue - £179.00
Kit includes 2 x 54 inch Tubes, 2 x 28 inch LED Tubes, Digital Controller - for effects, clips & screws, and instructions.
We can ship these kits Worldwide!
Shipping Options:
United Kingdom - £5 Europe - £15 USA & Rest of World - £22
HaBBicH
Prispevkov: 871
Kraj: Kranjsterdam
Se ne izplaca, lahko,ce sam delas, pol ceneje skoz prides
Žažko
Prispevkov: 179
Pridružen: 19 Feb 2003, 00:45
Odgovor Napisal/-a Žažko »
Men se pa ne zdi drago!!!
Je pa res da bos mogu se enmu autoelektricarju pol mal odcolat! :?
MDeeJay
Prispevkov: 506
Kraj: MARIBOR CITY
To itak vem pa ni blem mam avtostromarja zastonj-no skoraj zastonj, ce odbijemo 500 sit za pir!!!Samo me zanima, ce je kvalitetno dovolj pa ce to dobr sajna??!!!
MDeeJay
Prispevkov: 506
Kraj: MARIBOR CITY
The advantages of LED Ground Lighting over traditional Neon Ground Lighting
1) Tough and Durable, the LED Tubes contain no glass and can flex with the vehicle's chassis.
2) LED Ground Lighting is brighter than any Neon Ground Lighting - even Streetglow.
3) They are unaffected by temperature and reach thier optimum light output immediately.
4) Lifetime of LEDs is approximately 100,000 hours, Neons are 15,000 hours if they don't break on a bump in the road or a "sleeping policeman" (speed control bump).
5) Safer - there is no glass to break, LEDs are made of resin and they are encased in a Polycarbonate tube for additional protection.
6) Low Voltage, they operate directly from 12 volts unlike all neons which require a voltage of at least 1,000 volts from an inline transformer.
7) More Modes, the LED Tubes can be set to light the underneath of your vehicle with a constant glow of variable brightness, or they can strobe, scan, chase, and flash with sub bass.
8) Beams of light, not just a glow but serious light output, the tubes give the appearance that they are on the road not the car.
9) Extra tubes can be connected to the controller which will follow the light modes of the other tubes. Up to 8 tubes can be controlled from one controller.
10) Easy to fit because everything is colour coded, you don't have to work out which wires go to the battery from the tubes and which wires go to the switches. All of the wires connect to the controller which connects to the vehicle's power.
11) Longer, most neons sold in the UK have a maximum length of just 39 inches.
12) 12 Months Warranty against defects in workmanship.
HaBBicH
Prispevkov: 871
Kraj: Kranjsterdam
Dej kup ce mas dnar...
Uno garancijo kr pozab, ker ce jo bos hotu uveljavljat bos mogu nazaj posiljat da ti ji priznajo(ce ti jo)-dodatni stroski
Žažko
Prispevkov: 179
Valda da se ti splaca pol!!!!
To sem slisu da so ledice velik bols za pod auto kokr pa neonke!!!!
Pa po slikah sodec res lepo sajna!!!
