Nastavitve pri IE
Re: Nastavitve pri IE
This problem can be resolved by adding an Open in new window entry in the right-click menu for URL files. Follow these steps:Stupo napisal/-a:Kje se nastavi, da ti odpre vsak link v novem oknu in ne v obstojecem?
Copy the following contents to Notepad, and save as "opennewurl.reg" (with quotes), and place it in the Desktop. Right-click opennewurl.reg file and choose Merge. You've now added the Open in New Window right-click entry for URL files.
REGEDIT4
[HKEY_CLASSES_ROOT\InternetShortcut\shell\open2]
@="Open in New window"
[HKEY_CLASSES_ROOT\InternetShortcut\shell\open2\command]
@="rundll32.exe shdocvw.dll,OpenURL %l"
Additionally, make sure that the Reuse windows for launching shortcuts option is disabled in the Internet Options Advanced tab.
Here is another tip and a note from D@ny:
Yesterday I discovered this tip for Internet Explorer 7. By following similar indications in http://windowsxp.mvps.org/ie/urlopennew.htm for adding the Open in New Window option for Internet Shortcuts, I add the Open in New Tab option by modifying Windows registry.
Copy the following text to Notepad and save it as opennewtab.reg:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\InternetShortcut\shell\OpenNewTab]
@="Open in New Tab"
[HKEY_CLASSES_ROOT\InternetShortcut\shell\OpenNewTab\command]
@="rundll32.exe ieframe.dll,OpenURL %l"
Je to to?
Hvala, to sem naredil, ampak odkar imam nov msn (8.1) mi vedno vsak link, ki ga kliknem v msnju odpre v oknu, kateri je ze odprt.
Naprimer imam odprt renault forum in mi da nekdo xxx link, ki ga kliknem in se odpre v tem oknu, v katerem je bil prej renault forum, namesto v novem.
