ah zj sm jo razdru cist polom od vezja... loti med zicami in vezjem so cist ... mah kaj... kr odlepleni... en clicker je polomln bomo probal zalotat pa bomo vidl kuga bo pol....
zele sam slike dubim pa vm pokazm kasn konektor je
Ziiga napisal/-a:okej need help... tole ta kontrola je od jaegerja al neki taga ozr ta logo je po celi kontroli...
bi se mogoce dal cip dobit? ozr vezje na urednem servisu?
Ja to mas original komande od Renault Blaupunkt radija to pride tak dolg konektor kot ISO za napajanje samo da je ozji .....za te komande vrjetno nebos dobil adapterja (vsaj jst jih nism, sem se pozanimal pri zastopnikih) .....edino ce bi sam kaj prevezel ....mam jst istga v avtu ce kaj pogruntas javi
n hitr zrisou tole shemo k naj nep bla tok zapletena
en del sheme spustu k zame ni bistven kr nebi rabu. dejansko se vid d vse dela na principu d se tokokrog sklene vrjetn d bi najmn kksn gumb mogu usposobt... upam no se bom se mau naukol pozanimu... le pa mogoce gdo tukej ve pa odgovor je dobrodosu
When I hooked this up to the tip of the remote conector jack on the Pioneer
I found the following functions seemed to work:
0 Ω Off (No apparent effect)
2.2k Ω Source (switch between CD and radio or OFF if > 2 seconds)
4.4k Ω Mute (toggles "ATT" on display with muted audio)
6.6k Ω List(Disp) (No apparent effect)
8.8k Ω Seek up (Search up-radio or next CD track - hold down to fast forward.)
12.1k Ω Seek down (Search down-radio or previous CD track)
16.8k Ω Volume up (Volume up)
23.6k Ω Volume down (Volume down)
33.6k Ω Select (No apparent effect)
48.6k Ω Mode (In radio mode switch between FM1,FM2 and MW.)
Haven't managed to get any effect on the ring connection of the remote jack
both tip and ring appear to be tied up to 5v tip (STRKEY1, pin 80 on PE5518A)
ring (STRKEY2, pin 47 on PE5518A).
Connecting various resistances between tip and ground of remote jack effectively pull STRKEY1 down to different voltages to trigger the remote control.
Se kr zanimivo ce to tako res deluje, da se odziva na velikost toka...pol je pa res preprosto usposobit te komande...
edino nisem cisto preprican glede "rdece" povezave...nima prevec smisla da je stikalo (spodnje desno) povezano za stikalom zgoraj desno...si preprican da je povezano tako? Ker vsa ostala stikala so povezana na maso (rjavo)...
