Clio dci na 6000RPM
Vse ostale teme
d_leonit
Prispevkov: 512
Pridružen: 21 Maj 2006, 14:32
Clio dci na 6000RPM
Odgovor Napisal/-a d_leonit »
Tukaj en posnetek predelanega cliota 1.5dci na 143hp, ki se lahko zavrti kar na 6000RPM. :twisted:
http://www.youtube.com/watch?v=1bZXRwXZfg4
Aja ta clio ima drugace 143hp pri 4900RMP in 270nm pri 2700RPM. Prava raketa :D
Ima pa GT1749V turbino, katero mislim namontirati tudi jaz v prihodnosti :wink:
Zadnjič spremenil d_leonit, dne 27 Jan 2007, 19:36, skupaj popravljeno 1 krat.
Bor
Prispevkov: 224
Pridružen: 06 Jun 2006, 21:54
Kraj: Tabor
Odgovor Napisal/-a Bor »
Sam ma pa cel light show po armaturki :)
d_leonit
Prispevkov: 512
Evo razlaga zakaj gorijo lucke:
A luz do ABS do STOP e do travão de mão estão sempre ligadas porque teve um problema na bomba do ABS e num sensor do ABS e ainda n fui resolver. As outras luzes acendem quando se calca a fundo, mas isso faz em todos os dCi com repros mais fortes... acho que tem a haver com um limitador qualquer... mas isso tb deve ser resolvido brevemente com outra repro.
:lol:
Tukaj pa bol bogi prevo z google translate-om
The light of the ABS of the STOP and the brake of hand is always on because it had a problem in the bomb of the ABS and in a sensor of ABS and still n I was to decide. The other lights light when if calca the deep one, but this makes in all dCi with stronger repros finds that it has to have with a limitor any but this tb must briefly be decided with another one repro.
Dejan
obi
Prispevkov: 1755
Pridružen: 27 Jun 2005, 18:08
Kraj: medvoški štajerc
Odgovor Napisal/-a obi »
lepo se suce
Štrom for wife, UPS for life.
Tommy30
Prispevkov: 1720
Pridružen: 18 Sep 2005, 16:22
Kraj: Domzale
Odgovor Napisal/-a Tommy30 »
Taki obrati so za dizla odlicni. 1. liga.
Pomoje ne bo docakal 15kkm z tako predelavo.
( diesel gori, bencin eksplodira - upam da je opazna razlika=))
GOLF VI. 1.2 TSI + 2.0 TDI
metallic
Prispevkov: 684
Pridružen: 12 Apr 2003, 14:29
Odgovor Napisal/-a metallic »
CE je dizl, bo pomoje hitr grel na oni svet. :wink:
Ampak men se zdi (po zvoku) da tole ni glih dizl, tut stevce ma od bencinarja... :?
SlikaSlika
d_leonit
Prispevkov: 512
Je dizel 100%.Pa stevece so imeli dizli enake bencinarjem do 2004 leta.Potem so pa zamenjali stevce.
clio_dizel
Prispevkov: 1433
Pridružen: 12 Mar 2006, 22:38
Kraj: Vrhnika
Re: Clio dci na 6000RPM
d_leonit napisal/-a:...Ima pa GT1749V turbino, katero mislim namontirati tudi jaz v prihodnosti :wink:
a se potem GT1541VNT sploh kej pozna??? al si ti dobu kaksne boljse napotke kot jaz :lol:
Drmo
Prispevkov: 2959
Pridružen: 08 Avg 2005, 10:52
Kraj: Garage
Odgovor Napisal/-a Drmo »
sam se ze tko matra nad 4500 obrati da je itaq brez veze. pr nizkih pa noro dobr pospesi :twisted:
Enigma motorsport
CliYo II
Prispevkov: 819
Pridružen: 21 Avg 2006, 10:31
Odgovor Napisal/-a CliYo II »
ce je tole res dizl pol ne bo vec dolg med zivimi...
kaj pa je naredu da ga loh vrti na 6000rpm... :?: ... sam nafta more zgoret u valju...ni to bencinar k sam eksplodira... :?
Ce mene prasate ma tale sam stevc od bencinarja...ker ma obratomer do 7000rpm...dizl ga ma pa do 5000 ce se ne motm...
clio_dizel
Prispevkov: 1433
Kraj: Vrhnika
CliYo II napisal/-a:...Ce mene prasate ma tale sam stevc od bencinarja...ker ma obratomer do 7000rpm...dizl ga ma pa do 5000 ce se ne motm...
d_leonit napisal/-a:Je dizel 100%.Pa stevece so imeli dizli enake bencinarjem do 2004 leta.Potem so pa zamenjali stevce.
cliyoII, a nimas ti tut stevca do 7k? jaz ga mam. pa mimogrede, portugalci so usekani, tko da je za verjet :lol: se pa strinjam da nebo dolgo ziv (motor mislm)
d_leonit
Prispevkov: 512
clio_dizel napisal/-a:
Hm seveda da bi se mogl poznt, ker ta kkk-kp35 tako ali tako ne da veliko od sebe :lol: . Je pa ta GT1749V seveda se bolsa. Bom se malo povprasal tega, ki je zmontiral GT1749V turbino pa sporocim(dobim tudi slike)
clio_dizel napisal/-a:cliyoII, a nimas ti tut stevca do 7k? jaz ga mam. pa mimogrede, portugalci so usekani, tko da je za verjet Laughing se pa strinjam da nebo dolgo ziv (motor mislm)
Kolikor vem ima ze novejso verzijo stevca, z velikim LCD-jem in 5k rmp na stevcu :D
Drmo
Prispevkov: 2959
Kraj: Garage
ah no...dizl je itak sam za na njivo :lol:
Enigma motorsport
FastDay
Prispevkov: 1293
Pridružen: 02 Avg 2005, 19:02
Kraj: Semič
Odgovor Napisal/-a FastDay »
Drmo napisal/-a:ah no...dizl je itak sam za na njivo :lol:
:smt034
Ja sam to je cist out ....kar na 6000 obrati ....mene ze pri srcu boli k pride na 5000 .... :roll:
d_leonit... a lahko zaupas kej si nabavu IC od bavarca ..pa kok soldi...lahk na PM :wink:
Tadej
Prispevkov: 3232
Pridružen: 27 Nov 2005, 16:30
Kraj: Kočevje
Odgovor Napisal/-a Tadej »
A tale posnetek ste vidl, k ma se vecji light show, s tem da se mu lucka za motor prziga :)
http://www.youtube.com/watch?v=ue-CIZROxkg&NR
