EZNPC What s the Best Helldivers 2 Super Credit Farm
Vse ostale teme
sandy66
Prispevkov: 13
Pridružen: 18 Apr 2026, 09:36
Odgovor Napisal/-a sandy66 »
Farm Super Credits fast in Helldivers 2 with quick Trivial runs, smart POI routing, and co-op bunker looting so you can unlock Premium Warbonds without spending real money.
If you're trying to unlock a Premium Warbond in Helldivers 2 without paying, Super Credit farming is still the cleanest way to do it. A lot of players get distracted by medals, samples, or random fights, but that usually slows the whole thing down. What works is simple: pick fast missions, hit the loot spots, leave, repeat. If you already use places like EZNPC to keep up with game currency or useful items in other titles, the same practical mindset applies here too: save time, focus on what actually moves the progress bar, and don't waste runs on stuff that doesn't help.
Start with the right mission loop
Trivial difficulty is where the grind feels best. The maps are smaller, the pressure is low, and you're not spending half the mission recovering from a mess that didn't need to happen. You want short deployments with easy objectives, not drawn-out clears. Finish the main task first so extraction is available, then sweep nearby points of interest on the way across the map. Once you get used to the layout style, you'll notice that some missions are just better for this than others. If a route feels awkward or too spread out, back out and queue another one.
What's actually worth checking
Not every stop is equal, and that's where people lose time. Bunkers are the big one, especially in co-op, because they can hold multiple loot pulls and they're often the most rewarding stop on the map. Locked containers are worth opening too, while sealed pods are more of a quick grab if they're already in your path. The trick is not to treat the mission like a full completion run. You're scanning, not sightseeing. If a section of the map looks empty or requires a long detour, skip it. You'll usually earn more by ending the mission early and starting the next one than by forcing one last corner of the map.
Solo runs and squad efficiency
Solo farming works fine, but it asks for discipline. Light armor helps, and so does anything that lets you keep moving without getting bogged down. Don't stop for every patrol. Don't turn a tiny fight into a two-minute delay. In a squad, things get better fast if everyone understands the plan. Split coverage without drifting too far apart, call out bunkers immediately, and avoid doubling back. A lot of groups waste good farming runs because one player starts chasing kills while everyone else is trying to keep the route tight. The smoothest sessions usually feel almost quiet. In, loot, out, next mission.
Turning credits into a Warbond
Once you hit 1,000 Super Credits, head to the Acquisitions menu and unlock the Premium Warbond you actually want. That only opens the track, of course, so you'll still need medals later, but it's smarter to separate those goals instead of trying to do everything at once. Premium Warbonds don't expire, which takes the pressure off a bit. If your only aim right now is access, keep the routine focused and repetitive. Plenty of players do exactly that, and some even mix normal farming with outside help like Helldivers 2 Boosting when they want to save time and get back to the fun part of the game, which is actually using the gear they've been working toward.
Best place to buy Helldivers 2 Iteams:1000 Medal + 2000 Super Credits,100K EXP + 50K Requisition Slips
