Farm Abhorrent Heart in bulk from Urivar's Hoard or Kurast Undercity, then spend 3 per Harbinger of Hatred chest after the kill for the fastest, cleanest endgame loot loop.
If you've been living in the Harbinger of Hatred loop for a while, you've probably noticed the biggest mistake people make with Abhorrent Hearts: they treat them like a summon item. They're not. You spend three hearts after the kill, just to unlock the chest, which changes the whole rhythm of the farm. That's why it makes more sense to stockpile them and run the boss in batches instead of blowing them the second they drop. A lot of players who plan their mats this way also keep other resources lined up through places like EZNPC, especially when they want a smoother grind and less wasted downtime jumping between activities. Once you start thinking of hearts as a limited currency rather than a random drop, your route gets a lot cleaner.
Best source if you want consistency
The most dependable place to focus is Urivar's Hoard. If your build clears that fight fast, don't overthink it. Beat Urivar, open the chest with 12 Judicator's Masks, and repeat. It's not flashy, but it works. You're getting a real shot at Abhorrent Hearts without depending on random world content to carry your session. That matters more than people admit. Plenty of players waste an hour chasing “variety” and end up with almost nothing useful. If Urivar is already easy for you, stay there until you've built enough hearts for 6, 9, or 12 Harbinger chest opens. That kind of planning saves more time than any tiny damage upgrade ever will.
When Urivar starts feeling stale
At some point, yeah, the loop can get old. That's where the Undercity of Kurast helps. Using a Tribute of Titans gives you another solid way to pull in Abhorrent Hearts while also stacking other Lair Boss materials. It's a nice change of pace, especially if you're running with a group and clearing fast. You won't always match the clean efficiency of an ideal Urivar route, but you do get better overall material variety. Random event drops and seasonal cache rewards still exist, of course, but they're not something you build a plan around. If they happen, great. If not, no big deal. You should always treat those as extra value, not the foundation of your farming route.
Small habits that save a lot of time
The boring stuff matters here. Keep your inventory under control. Don't stop every few minutes to inspect low-end loot you already know you won't use. Don't let your stash turn into a mess halfway through a farming session. That kind of friction adds up fast, and you feel it more during endgame loops than anywhere else. It also helps to match your route to what your build already does well. If you melt Urivar, commit to that. If your group flies through Kurast, lean into that instead. The best route on paper isn't always the best route for your character. The one that keeps you moving usually wins.
How to spend hearts without wasting them
When you're ready to cash in, do the simple math first. Three hearts per chest means every farm session should be built around multiples of 3. That sounds obvious, but loads of players still go in half-prepared and break their momentum after one or two runs. The smoother play is to line up a full batch, knock out the boss, open the chest, reset, and keep rolling. That's where the real efficiency kicks in. If your goal is better loot in less time, batching runs beats single clears every day, and having the rest of your setup ready, including things tied to Diablo 4 Gold, makes the whole endgame loop feel far less stop-and-start.
