Moja limona - clio
Pa je prisla na vrsto avtoakustika
V vratih so 16ke impulse mb650, distancnik je pa debeline 16mm, tako da gre serijska mrezica se normalno gor.
Tweeterji so tudi impulse in sem jih spravil na originalno mesto, samo armaturo je bilo potrebno sneti dol, ker so malo vecji:
Tweeterje poganja blaupunkt gtaII, 16ke pa impulse sd500.
Hvala terminatorju za pomoc, in obiju za nasvete
Malo sem se se igral s potovalnim racunalnikom in sem ugotoviv da ima tudi moznost prikaza porabe v litrih na uro in da pokaze koliko goriva je v rezervoarju.
Mogoce kdo ve kaj je tale t---h zaena zadeva?
Zaenkrat je to to, ta mesec dam barvati se letvice in prage, pa zmontiram sobe za pranje zarometov, drug mesec pa naprej.
- killah bee
- Prispevkov: 4094
- Kraj: Ljubljana
Tuki imas iz angleskega foruma za kode
Theres a simple diagnostics built into the Mk2 Clio's
To access this, with the igition off press and keep hold of the button at the end of the stalk and turn the ignition on. ALl the dashboard warning lights will come on and the speedo and rev counter will go through a predefined sequene.
When your doing this though (you can let go of the button at the end of the stalk) ever time you press the stalk button the digital readout will show information (listed belew) each time you press the button some more information will show.
All the lights lit (shows if you have a failed LED).
The amount of fuel left in the tank in liters.
Fuel flow (the engine has to be running. This is in liters per hour
Stored faults
t mean an injection fault has been detected for a minimum of 4 seconds
J means a fault has been noted on the fuel gauge. It must have disconnected for longer than 100 seconds. The resistance from the fuel tank sensor needs to be between 5 and 350 Ohms.
d means an injection signal fault has been detected
h means an oil level sensor fault has been detected. Resistance from the sensor should be between 6 and 20 Ohms. Any reading over 20Ohms is an open cicuit anything under 3 is a short circuit.
If no faults are logged then dashes will show fixed dashes.
Press the reset button to clear the logged faults. Other faults arn't shown on the display.
- Terminator
- Prispevkov: 442
- Pridružen: 06 Sep 2007, 15:21
- Kraj: lj
