Multicolor LED osvetlitev stopalk
Vse o videzu avtomobila
birkoff
Prispevkov: 1168
Pridružen: 26 Apr 2004, 00:05
Odgovor Napisal/-a birkoff »
Chip napisal/-a:A mislis ledic? Po 3X 5mm gredo not.Odvisno od luknje.Pri prejsnjem modelu Clia so sle celo 4 notr
Chip
To sem mislo ja.. tnx za info!
Katere pa si dal.. kar one modre, ki majo visoko svetilnost in so prozorne ce jih gledas ko ne svetijo?
MDeeJay
Prispevkov: 506
Pridružen: 05 Mar 2003, 02:37
Kraj: MARIBOR CITY
Odgovor Napisal/-a MDeeJay »
CHIP EVO TI TVOJO IDEJO ZE ZDAVNAJ NARJENO http://www.litewave.co.uk/iceled_flood.htm
PA BREZ ZAMERE!!! :wink:
CHIP
CHIP
CHOP :lol:
Chip
Prispevkov: 318
Pridružen: 30 Maj 2003, 08:26
Odgovor Napisal/-a Chip »
MDeeJay napisal/-a:CHIP EVO TI TVOJO IDEJO ŽE ZDAVNAJ NARJENO http://www.litewave.co.uk/iceled_flood.htm
CHIP
CHIP
CHOP :lol:
Res je! Kaj cmo, potem sem dober da se kosam s takimi firmami in razvijalci :lol: .Malce drugace narejeno, ampak podobno!
Mi vsaj ni treba kupovati :lol:
Chip
MDeeJay
Prispevkov: 506
Kraj: MARIBOR CITY
SAMO NI MI JASNO, V CEM JE RAZLIKA MED TEM:http://www.litewave.co.uk/iceled_flood.htm
IN TEM:http://www.litewave.co.uk/iceled_spot.htm
NO TU JE OBRAZLOZENO SAMO NAJ MI NEKDO POVE PO DOMAĆE:
ICELED FLOOD provides a powerful, high quality light beam ideally suited to floodlighting interior and an external model for outside areas. This compact light source can be surface-mounted to provide light wherever it's needed. The wide-angle beam ensures an excellent spread of light even at close range. Compared to ICELED SPOT the beam is equally as bright but covers more than twice the area.
HVALA
Chip
Prispevkov: 318
MDeeJay napisal/-a:SAMO NI MI JASNO, V CEM JE RAZLIKA MED TEM:http://www.litewave.co.uk/iceled_flood.htm
NO TU JE OBRAZLOŽENO SAMO NAJ MI NEKDO POVE PO DOMAĆE:
HVALA
A ne ves kaj je po anglesko SPOT in FLOOD.
Kakor jaz razumem je pri FLOOD svetloba bolj razprsena, pri SPOT pa je bolj tockasta.Verjetno ena uporablja "ovalne" ledice, druga pa "okrogle".
Chip
Zadnjič spremenil Chip, dne 10 Avg 2004, 16:56, skupaj popravljeno 1 krat.
MDeeJay
Prispevkov: 506
Kraj: MARIBOR CITY
Hvala!Samo kaj ko je kurba funt tak drag!!! :x
Chip
Prispevkov: 318
MDeeJay napisal/-a:Hvala!Samo kaj ko je kurba funt tak drag!!! :x
Aneda, vi bi pa vsi zastonj al pa par jurjev :lol:
Pa se vsega je samo 12 ledic not :lol:
Chip
